CAT Control issue WSJT-X->RUMlog using Kenwood TS590S
I cannot see it on the Apple Store nor in the Downloads section. How can i get it?
Funny how this board doesn't have the ability to delete your own account.
Re: 3.7?
Got it, thanks! Now this bl**dy setup.
WSJT-X and RumlogNG on the same machine. I followed the instructions in the WSJT-X and RUMlog section of the help. IP address used for all settings is 127.0.0.1 as mentioned in the manual.
RUMlog sees the connection to the radio, but doesn't follow. I need to Reset Cat a few times for RUMlog to show the new frequency.
Switching bands in WSJT-X doesn't switch the radio.
Switched from using 127.0.0.1 to the real internal IP address in the 192.168 range. This solves the Follow TRX issue in RUMlog.
Switching bands in WSJT-X still doesn't switch bands on the radio. Test CAT and Test PTT in WSJT-X work as expected. When switching the bands manually using the radio both WSJT-X and RUMlog follow correctly.
How can i make sure WSJT-X is sending the band changes to RUMlog?
Ton.
Ton.
Re: 3.7?
I was using Wireshark and when i switch from 20m to 15m in WSJT-X.
I can see the XML with the CmdSetFreMode request being sent to port 7374, but then i immediately get another GetCmdFreq and a response with 14.074 as frequency. So WSJT-X assumes the radio is on 20m and will not switch to 15.
Does that make sense?
Ton.
Ton.
Re: 3.7?
- You have to get CAT control from RUMlog working first - without Fldigi and without WSJT-X
- Changing ip addresses can not affect your serial CAT connection.
- ip addresses may change. You should use localhost or 127.0.0.1
- Why do you have set the Power up RTS line option? This may interfere your connection.
- You have selected two PTT options for WSJT. Deselect the PTT option in RL --> UDP --> WSJT-X or set in WSJT-X --> Radio --> PTT Method to None
Re: 3.7?
CAT control works correctly in RUMlog.DL2RUM wrote:You have to get CAT control from RUMlog working first - without Fldigi and without WSJT-X
I know. I find this strange as well. Maybe because i have A LOT of interfaces in my Mac.DL2RUM wrote:Changing ip addresses can not affect your serial CAT connection.
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether f4:5c:89:ac:1a:41
inet6 fe80::e1:7aab:d1d2:32d6%en0 prefixlen 64 secured scopeid 0x5
inet 192.168.1.56 netmask 0xffffff00 broadcast 192.168.1.255
media: autoselect
status: active
en1: flags=963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX> mtu 1500
options=60<TSO4,TSO6>
ether 4a:00:05:0e:dc:f0
media: autoselect <full-duplex>
status: inactive
en2: flags=963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX> mtu 1500
ether 4a:00:05:0e:dc:f1
status: inactive
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
ether 06:5c:89:ac:1a:41
media: autoselect
status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1484
ether c6:07:6e:33:c6:2d
inet6 fe80::c407:6eff:fe33:c62d%awdl0 prefixlen 64 scopeid 0xa
media: autoselect
status: active
bridge0: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x2
member: en1 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 6 priority 0 path cost 0
member: en2 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 7 priority 0 path cost 0
media: <unknown type>
status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::791d:91cc:d40:332b%utun0 prefixlen 64 scopeid 0xc
en7: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 00:e0:4c:68:e7:67
media: autoselect (none)
status: inactive
en4: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=10b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV>
ether 38:c9:86:24:51:0a
status: inactive
I will follow your advice.DL2RUM wrote:ip addresses may change. You should use localhost or 127.0.0.1
Unchecked. Don't see a difference.DL2RUM wrote:Why do you have set the Power up RTS line option? This may interfere your connection.
There is no WSJT-X --> Radio --> PTT Method --> None so i did the first option.DL2RUM wrote:You have selected two PTT options for WSJT. Deselect the PTT option in RL --> UDP --> WSJT-X or set in WSJT-X --> Radio --> PTT Method to None
All IP addresses set to 127.0.0.1 instead of 192.168.1.56. RUMlog follows the radio correctly. WSJT-X follows RUMlog correctly.
Radio doesn't follow the band change in WSJT-X.
