Small issue
Small issue
Hello everybody
I'm Marco IU2DXF.
I use RumlogNg as my primary logging platform on my mid 2009 macbook pro 13" (Yosemite 10.10.5)
Everything works flawlessy except for a small issue (maybe is not an issue...it's just the program working that way...): isn't there a way to make the frequency indicator move when i move the VFO?
I cannot understand if it's something that i haven't enabled or something else.
Radio is a Kenwood ts 590s linked to my mac with a USB cable
Thanx in advance.
Marco IU2DXF
I'm Marco IU2DXF.
Thanx in advance.
Marco IU2DXF
Re: Small issue
Is the frequency readout correct? Can you control the TRX from the Mac?
Please post a screen shot of your TRX settings.
Re: Small issue
with "settings" you mean this?
thank you so much for your time
Re: Small issue
Re: Small issue
Yes, the readout is correct.
The trx is controlled without any issue from the mac both in frequency and modulation (CW, USB,LSB,FSK).
I can even send cw messages from the "CW" menu.
Re: Small issue
Nope.
I don't know if that's an issue or not, but I would like the frequency indicator on the main logging window changing when I move the VFO on the radio. So that if I move on the band (or change band) and find something interesting i can log the qso just typing the call without thinking about the frequency.
thanx
thanx
Re: Small issue
What are you talking about? You wrote, the frequency field shows the correct value!
Re: Small issue
Ok, maybe we got a little misunderstanding here, sorry about that
When i move the VFO on the radio the frequency indication ON THE PROGRAM does NOT move with it.
Sorry if I haven't understood your question
Re: Small issue
As far as I know, the TS-590 uses RTS/CTS for flow control. Make sure, the setting matches the setting in your transceiver (if applicable)
