MAC Yosemite Serial Cable
k8khz
Unread post by k8khz »
I am using a USB serial adaptor it shows up on the Device list. But not in the rumlog as a device. Not sure why that is. Anyone? Thanks.
Re: MAC Yosemite Serial Cable
You haven't installed the correct device driver.
k8khz
I have the ATEN driver up to date. do you have another driver? Using this http://www.aten-usa.com/products/produc ... R1SbVxHHBI
k8khz
To be exact I have this here http://www.iogear.com/product/GUC232A/ I went to the drivers for my iMac and got the latest one Sept 2014.
You should ask the manufacturer if it works for 10.10
K3DCW
Unread post by K3DCW »
k8khz wrote:To be exact I have this here http://www.iogear.com/product/GUC232A/ I went to the drivers for my iMac and got the latest one Sept 2014.
If you had a driver that worked for Mavericks, odds are it will still work for Yosemite, but if it isn't signed then Yosemite won't load it. The easy way around that (until you can get signed drivers) is to put the KEXT security into developer mode:
Go to the terminal and enter the following:
sudo nvram boot-args=“kext-dev-mode=1”
<enter your password when requested>
sudo reboot
This will allow the unsigned drivers to load. In fact, it will allow any unsigned drivers to load, so use it with caution. There's a reason why Apple decided to lock down the drivers (security) and if you bypass it and something goes wrong, know that you've been warned. That being said, I've been running in developer mode since the day Yosemite came out (my Navigator does not yet have signed drivers) and I've had no issues.
Dave
K3DCW
"Hamming it up on macOS"
