Error uploading to LowW
K8AJS
Unread post by K8AJS »
I'm starting to move my log records over to RumLog and using it in my daily operation, hoping to make a full transition very soon. I'm reading the manual and going up the learning curve, but I'm having a problem attempting to upload to LotW.
I select the QSOs in the log table and click on "LotW Out" in the QSL menu, and the procedure starts, I choose my station location and click "OK," and I get an error window that says, "tqsl Error, Cancelled by user" and the action aborts. What can be causing this problem?
John K8AJS
bastinj@gmail.com
John Bastin K8AJS
bastinj@gmail.com
Re: Error uploading to LowW
No other messages seen? Please check Console for further errors. Do you have entered your path to the .tqsl folder? Is your station location and your callsign seen in the preferences?
K8AJS
DL2RUM wrote:No other messages seen? Please check Console for further errors. Do you have entered your path to the .tqsl folder? Is your station location and your callsign seen in the preferences?
Yes, I have the path to the .tqsl folder. TQSL starts and runs long enough to ask for the certificate selection. My station location and callsign are present in all the needed places.
If I run TQSL standalone and upload a file, it works just fine.
Also, if I click on "LotW In," it says "Connecting..." for a while, then times out.
Here is the console log after the upload attempt:
2015-03-19 07:14:34.697 tqsl[5064]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.2 instead of 10.10.2. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
2015-03-19 07:14:34.698 tqsl[5064]: 0 CarbonCore 0x934d67c7 ___Gestalt_SystemVersion_block_invoke + 135
2015-03-19 07:14:34.698 tqsl[5064]: 1 libdispatch.dylib 0x931fe0b5 dispatch_once_f + 251
2015-03-19 07:14:34.698 tqsl[5064]: 2 libdispatch.dylib 0x931ff0d8 dispatch_once + 31
2015-03-19 07:14:34.698 tqsl[5064]: 3 CarbonCore 0x93468e88 _Gestalt_SystemVersion + 1050
2015-03-19 07:14:34.698 tqsl[5064]: 4 CarbonCore 0x93468a39 Gestalt + 150
2015-03-19 07:14:34.699 tqsl[5064]: 5 tqsl 0x000d4f52 _Z14UMAInitToolboxtb + 50
2015-03-19 07:14:34.699 tqsl[5064]: 6 tqsl 0x000e3b8c _ZN5wxApp10InitializeERiPPw + 44
2015-03-19 07:14:34.762 Dock[312]: no information back from LS about running process LSASN:{hi=0x0;lo=0x1a81a8}
2015-03-19 07:14:36.096 appleeventsd[26]: <rdar://problem/11489077> A sandboxed application with pid 5064, "" checked in with appleeventsd, but its code signature could not be validated ( either because it was corrupt, or could not be read by appleeventsd ) and so it cannot receive AppleEvents targeted by name, bundle id, or signature. Error=ERROR: #100001 { "NSDescription"="SecCodeCopyGuestWithAttributes() returned 100001, -." } (handleMessage()/appleEventsD.cp #2100) com.apple.root.default-qos
2015-03-19 07:14:36.219 sandboxd[3289]: ([26]) appleeventsd(26) deny file-read-data /Applications/Amateur Radio/TrustedQSL/tqsl.app
2015-03-19 07:14:36.225 sandboxd[3289]: ([26]) appleeventsd(26) deny file-read-metadata /Applications/Amateur Radio/TrustedQSL/tqsl.app/Contents
2015-03-19 07:14:36.230 sandboxd[3289]: ([26]) appleeventsd(26) deny file-read-metadata /Applications/Amateur Radio/TrustedQSL/tqsl.app
2015-03-19 07:14:36.234 sandboxd[3289]: ([26]) appleeventsd(26) deny file-read-data /Applications/Amateur Radio/TrustedQSL/tqsl.app/Contents/MacOS/tqsl
2015-03-19 07:14:47.883 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
2015-03-19 07:14:47.886 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
2015-03-19 07:14:47.887 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
2015-03-19 07:14:47.888 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
2015-03-19 07:14:47.890 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
Thanks for your help.
John K8AJS
bastinj@gmail.com
John Bastin K8AJS
bastinj@gmail.com
Is your call sign and your station location seen in the RUMlog Preferences under the LoTW tab?
Please post a screen shot of this settings.
K8AJS
DL2RUM wrote:Is your call sign and your station location seen in the RUMlog Preferences under the LoTW tab?
My callsign is there. My location says "Ask for" and I answer that question from TQSL when I do the upload, because i have more than one active certificate in TQSL. When I tried to do the upload, TQSL ran and asked me for my selection, where I selected "K8AJS" in this case.
John K8AJS
John Bastin K8AJS
bastinj@gmail.com
Your settings are looking good, hard to trouble shoot from here.
Is the popup (where you have selected 'Ask for') filled with all of your locations?
Which tqsl version do you use?
K8AJS
DL2RUM wrote:Your settings are looking good, hard to trouble shoot from here.
Yes, the popup shows all the locations, as does the TQSL app when it asks me to select the certificate. I"m using TQSL version 2.1 at the present time.
On further thought, I'm going to ask you not to work any more on this; I've decided not to make the change to RumLog at this time. I've been working with it this morning, and it's just going to be far harder to try to move all my log and all my information than I expected. I have a log that currently contains 136,946 QSOs, a total of three callsigns, and I have another couple of thousand left in paper logs that I'm typing in, before it will be complete. I've decided to stick with my existing log for now. I'm accustomed to it. Its only disadvantage is that I have to run it in Windows (I'm using a VM on my MBP), but I've been using it for 13 years, I can continue to do it...:-)
Thanks for helping out, and best wishes!
John K8AJS
bastinj@gmail.com
John Bastin K8AJS
bastinj@gmail.com
