Tom, Do you have any plans to post a what is working and what still needs to be completed?
With my IC-735, Winkeyer, and Signalink station the interface to the radio is working flawlessly for radio control. I love the new interface for spots and DXCluster. Both Grayling and Sun windows worked properly. With that being said a few things I noticed so far:
- Cocoamodem interface removed ( Is the plan for digital modes to use FLDigi by default? )
- FLDigi not communicating with RUMlogNG ( tested by copying settings from RUMlog and having FLDigi using xml-rpc, no band change seen on FLDigi )
- Winkeyer settings, It is not clear that the macros defined in the settings will write to winkeyer or are the ones used for CW mode.
- No online lookups for QRZ or HamQTH (auto or manual (could not find the key sequence for either)
Keep up the awesome work and I look forward to what you do with RUMlogNG
73 de KF5JRA
Ron
