EI2KK
Unread post
by EI2KK »
Hi
Is there any API (UDP?) I could use to send/change frequency and set value to callsign field?
- Administrator
Unread post
by DL2RUM »
You can use:
- Apple Script - see Function Library
- UDP in the Flex Radio export format (N1MM Import)
- UDP in the N1MM export format
