second call sign
Posted: Wed 12. Jul 2017, 15:53
by hanz
Dear OM,
For several month a year we live in Latvia where i have my other callsign.(YL3JD)
Is it possible to log qso's in rumlog with a second callsign?
73's hanz de pa3zz
Re: second call sign
Posted: Wed 12. Jul 2017, 15:59
When you are operating from different DXCC entities, you can't use the same logbook file.
Posted: Fri 14. Jul 2017, 05:37
by hanz
DL2RUM wrote:When you are operating from different DXCC entities, you can't use the same logbook file.
That's the case, i work from diff entities.
73' hanz
Posted: Fri 14. Jul 2017, 06:02
by DJ2RB
In this case, you must install a new logfile fer the secand call.
vy 73 Rolf
Posted: Fri 14. Jul 2017, 22:00
by hanz
DJ2RB wrote:In this case, you must install a new logfile fer the secand call.
vy 73 Rolf
Hi Rolf,
If i understand correct, you mean i have to run a second copy of Rumlog. Running seperatly from the other one?
An other question, can I add a new mode, FT8?
73's
hanz
Posted: Sat 15. Jul 2017, 08:19
Hanz, you can't run multiple instances of RUMlog. You have to create a new Logbook file. See the Logbook menu.
Posted: Sun 16. Jul 2017, 11:24
by hanz
DL2RUM wrote:Hanz, you can't run multiple instances of RUMlog. You have to create a new Logbook file. See the Logbook menu.
Thanks, works perfect.
73's hanz
Posted: Sun 16. Jul 2017, 12:12
by hanz
Sorry to keep asking questions.
Is it possible to change the directory of the log files.
I have got two at the moment, never thought of having two and i want to place them on e specific place, also got to do with auto backup.
I tried several things l;ike crerating an empty log and copy the old one over it etc.. but taht doens't work.
Is there a way to do this?
Thanks for your patience.
73 hanz
Posted: Sun 16. Jul 2017, 12:39
- Quit RUMlog
- Move the used file wherever you want
- Restart RUMlog
- Use the Menu-->Logbook-->Open Logbook to navigate to your file
The last step isn't required, when you use RUMlogNG, due to the Sandbox structure.
Posted: Sun 16. Jul 2017, 12:52
by hanz
DL2RUM wrote:- Quit RUMlog
- Restart RUMlog
Thanks thanks.
I know what went wrong here.
The main logging window wasn't openend and then open logbook is greyed out.
When the main log window is opened then open logbook is black and i can select the log file where ever i like.
I will not bother you again
Have a nice weekend and thanks for the quick responses.
hanz 73's
