MBP Pro 2016 USB-C
Posted: Sun 18. Dec 2016, 12:25
by ea5xq
Hi all
So far I have been using RUMlogNg connected to my IC756 and FT857 via USB with my MBPro 2012 without any troubles (activating CAT correctly etc..), however I have just changed to the new MBP 2016 with Touch Bar and it seems that the things will not be the same.
MBP 2016 comes with USB-C ports so you need a adapter to USB in order to manage the rigs. I did it and I does not work. no way to control from RUMlogNG the rigs. Any of you in the same situation?
In parallel with my tries, I am going to prepare a workaround. I have a Raspberry Pi that I used for controlling remotely my FT817, so I was thinking to use it to link RUMlogNG with the rigs via IP , is it possible? any experiences with that configuration? Is it possible from RUMlogNG to access somewhere else that could control the rigs via LAN?
Thanks for your comments
73s Juan, EA5XQ
Re: MBP Pro 2016 USB-C
Posted: Sun 18. Dec 2016, 15:53
Just tested the major three on a trx: Silicon Laboratories, FTDI and Prolific. All work as expected out of the box. There was no need to reinstall a driver, I migrated all data from a Time Machine backup. I used a simple €2,99 USB-C to USB-A converter plug.
RUMlog can control a trx via LAN. On the other end you need a tcp/serial converter.
Posted: Sun 18. Dec 2016, 16:03
by ea5xq
Probably I had something strange in my configuration, I have just reinstalled the driver and now it works like a charm.
I will try the control via LAN for this Xmas holidays ... now at least it works!
