Colors in Spot window but no notifications, is this possible
Posted: Sun 2. Oct 2016, 05:44
by EA3HOE
I want to see what i need to work in my Spots window, but i don't want the notification. Maybe it's a bug, maybe i'm doing something wrong, but when i select what i want to have marked in the Preferences/DX Alarms dialog i automagically get Growl notification as well. And yes, my Growl notification check box is off.
Is it possible to have colors without notification?
Re: Colors in Spot window but no notifications, is this poss
Posted: Sun 2. Oct 2016, 10:03
RUMlog shouldn't send Growl notifications when you have deselect it. Maybe you see the macOS notifications?
The Growl selection was introduced for compatibility reasons on older systems only. You should set your desired options always in the Notification Application itself. Set the options for your convenience in the Growl preferences and the Notifications settings.
Posted: Sun 2. Oct 2016, 10:07
by EA3HOE
DL2RUM wrote:RUMlog shouldn't send Growl notifications when you have deselect it. Maybe you see the macOS notifications?.
Probably. I am a long time Mac user so i tend to mix those two up. Is there a way to suppress the OSX notifications?
Posted: Sun 2. Oct 2016, 10:23
You have to go to the Notifications Preferences.
Posted: Sun 2. Oct 2016, 10:42
by EA3HOE
DL2RUM wrote:You have to go to the Notifications Preferences.
Sure. Thanks. I am still figuring out how to retain the window locations as well.
