RUMlogNG - LoTW and eQSL error log
Posted: Mon 29. Aug 2016, 14:45
by ok3ar
At first - thank you for the RUMLOG - for me is the best logging program at all. Really.
And now, my (but probably not only my) “problem” :)
I worked 99% on the portable. I have a accounts with the /P on the LoTW and eQSL too. But.. :)
Many stations have send the QSL as “main call” only (not with /P suffix). This error is clearly on the side of the sending station (operator). In this case, we do nothing else than a QSO reject and notify the sender. I write instructions on the my QRZ page, but the error still appears.
From the eQSL service, if i have a “red” QSO after “eQSL in” command in RUMLOG, i can go to www site and manually refuse the QSO and i can write to sender a message. But in LoTW i can only see the “red QSO” in the “LoTW in” table, but i not found any feature, how i can save this error logs for future use (sending email to sender for example).
Very I would have liked the the option to add to the program, that would allow these “bad” QSOs somewhere view (ideally with connections to the station page on the QRZ or hamQTH.com which could be clicked e-mail address.
I went through the entire forum and unfortunately I have not found a solution.
Thank you for answer.
Richard.
Re: RUMlogNG - LoTW and eQSL error log
Posted: Mon 29. Aug 2016, 16:12
I understand you problem fully.
Currently I don't have an idea how to solve it. There is no provision for something like this.
You could use the Print function (Menu-->Edit-->Print) to save the errors for a later assessment.
Posted: Tue 30. Aug 2016, 11:25
by ok3ar
Thank you, Tom. It is not a bad idea, next time I'll try it this way.
73!
Richard
