Contest QSO history in Main Logging Window
Posted: Mon 9. May 2016, 17:04
by K9QJS
When I am researching old QSOs in the Main Logging WIndow, it is helpful to know if a QSO in my log was done during a contest and, if so, what the contest exchanges were for that contest. Is there a way to do that?
Re: Contest QSO history in Main Logging Window
Posted: Mon 9. May 2016, 18:04
You have Import the contest QSOs into your logbook. At this point you will loose the exchange information. Never heard that somebody want to know this.
Posted: Mon 9. May 2016, 20:10
by K9QJS
Tom - Thanks for the reply! When I get QSL card requests in the mail, I like to be able to reference the contest that I may have worked them during. I have also, for good or bad, used the contest fields for the US National Parks on the Air program prior to my starting to use RumLogNG and that was how I kept track of what NPOTA units I had thought I had worked. That's not a correct use of those fields, I know. Also, I imported all my previous QSOs into RumLogNG when I started to use it a few months ago and, though infrequently, I have looked back to see what contests I had worked. Thanks again for your work on RumLogNG. 73, Hoop K9QJS
Posted: Mon 9. May 2016, 20:29
You could set one user field to <contest_id>. When importing a contest file, this field will be filled with the contest name automatically.
Posted: Mon 9. May 2016, 20:45
by K9QJS
Thanks! I will do that!
