Problem with DIG + WSJT
Posted: Sat 9. Apr 2016, 13:58
by ea5xq
Hi
After moving to 2.7 (probably that is not the reason) I am facing some troubles for digital comms either with WSJT or FLIDIGI. It is able to receive the signals but when order is done to transmit it does not transmit anything ... (it activates the FT857 but not data is transmitted).
May I download the 2.6 version to test it with the previous one? if so, from where?
Re: Problem with DIG + WSJT
Posted: Sat 9. Apr 2016, 18:19
RUMlog can switch the PTT for you, nothing else. The problem must be in your audio signal path.
