TQSLLib Error
Posted: Mon 1. Feb 2016, 17:33
by ea5xq
Hi
When trying to connect with LoTW (out for new QSOs) I receive TQSLLib error. No messages in Console.
I have checked all my certificates in LoTW TQSL app and all of them are ok.
Version 2.4 (but tested with 2.5.2 too)
Please advice
Best
Re: TQSLLib Error
Posted: Mon 1. Feb 2016, 17:55
Check the QSO date slot in your certificate.
Re: TQSLLib Error
Posted: Mon 1. Feb 2016, 18:06
by ea5xq
I have several certificates (different call-signs) but all of them are in the range of the QSOs stored in the log.
Best
Re: TQSLLib Error
Posted: Mon 1. Feb 2016, 18:12
Can you show us a screen shot of a certificate?
Re: TQSLLib Error
Posted: Mon 1. Feb 2016, 18:13
by ea5xq
Here it is
Re: TQSLLib Error
Posted: Mon 1. Feb 2016, 18:24
Looks good, You should check now the logs in the hidden ~/.tqsl folder. Files are named curl.log and dberr.log.
Re: TQSLLib Error
Posted: Mon 1. Feb 2016, 22:28
by ea5xq
Here is the curl.log.
Dberr.log only says "BDB1565 DB->compact: method not permitted before handle's open method"
Re: TQSLLib Error
Posted: Tue 2. Feb 2016, 06:31
You should ask the tqsl author. Can you upload the log without using RUMlog?
Re: TQSLLib Error
Posted: Wed 10. Feb 2016, 16:07
Here a solution from Dan, KJ6RGX. He has had a similar problem.
The easiest thing to do for a Mac user is to open a Terminal window, then type the following commands at the prompt:
cd $HOME/.tqsl
rm duplicates.db  __db.*  log.*
Re: TQSLLib Error
Posted: Wed 10. Feb 2016, 17:21
by ea5xq
Thanks!
I have performed the commands but the error is still there. I will try to upload manually (with TQSL program) the logs just in case it shows up any other error
Best
