Digimaster Pro 3
m0pkz
Digimaster Pro 3
Unread post by m0pkz »
Is any body using Digimaster Pro 3? I'm looking some advice how to configure Winkeyer! http://www.g4zlp.co.uk/unified/DigiMaster_ProThree.htm
Regards, Kes. m0pkz
Re: Digimaster Pro 3
So far I can see from the site, you will find 3 new com ports when the interface is plugged in.
What is your problem exactly?
m0pkz
Sorted now :) it's working!!! Thank you Tom!
I hope the Winkeyer works. I've just ordered the CW keyed from this site. I like the slime design.
m0pkz
Yes it's works. Only the thing Tom, can't get FLDIGI send CW. FLDIGI seems didn't got winkeyer option.
Regards, Kes.
kf5jra
Unread post by kf5jra »
You can have RumlogNG send CW and use FLDigi as your skimmer. the only trick is to make sure rumlogng has focus and not fldigi.
Hope this helps.
Kes,
I got my G4ZLP cw keyer yesterday and have had some problems. Speed setting and returning the control to the speed pot works slightly in a different way. I have added an option to select which "Winker" is used: K1EL, K3NG or G4ZLP.
