QRG Band edges
Posted: Sat 8. Aug 2015, 20:29
by N8XMS
I am in the process of setting up RumLogNG and I have a question about the QRG band edge settings in the Preferences. How does RumLog use these values? Also what should I do here in the United States where data and CW overlap so much? (I operate 99.9% CW but do a little PSK31 on very rare occasions.)
Thank you in advance for any replies.
Paul - N8XMS
Re: QRG Band edges
Posted: Sat 8. Aug 2015, 21:36
The most lower and upper values are used to define the band itself. The frequency field will be orange backgrounded, when you have tuned out of the limits. Further, dx-cluster spots will be assigned to a band, using the edge frequencies.
Our 80m band goes up to 3.800 kHz only. With my settings, a dx-spot on 3.820 will not be shown in my 80m band table!
The edges between the different modes will be used twice:
  • Using the table, dx-spots will be assigned to a operating mode.This (assumed) mode is shown in the dx tables and will be used to inform you on a possible new one in this mode. This can't be work perfectly, but outside a contest it may be 99% correct.
  • When you tune a frequency in your tx using CAT, the mode according the frequency table will be set as well. You can't set the operating mode direct in RUMlog. Enter 14005 in the callsign field and the trx will switch to CW, enter 14195 and the trx will switch to SSB.
Re: QRG Band edges
Posted: Mon 31. Aug 2015, 12:44
by kbijl030@gmail.com
De dxcluster venster after the filtering (or no filtering , such as mine) is not displaying in the loper window 144 and 430 and over bands, can you publish in this forum whatsapp the real data for the config of dxcluster is ? Or tell me in dom people lang. What the exact functions are from the edge fone/cw and so on
Thanks for Your text
Re: QRG Band edges
Posted: Mon 31. Aug 2015, 15:21
by ik2eae
I got some problem but ony on 144 MHz. On DX Spot Windows I have always 2 question mark in the "MODE" column . I change the value on preference without solution on 2m.
My configuration is: 144000-144100-145000-146000 there's something wrong?
Re: QRG Band edges
Posted: Mon 31. Aug 2015, 15:30
On 2m and above the mode recognition is very unreliable, thats why I disabled it.
Re: QRG Band edges
Posted: Mon 31. Aug 2015, 15:39
by ik2eae
ok I stop to try, I thought it worked. I work on ssb that's why I try to fix
Re: QRG Band edges
Posted: Tue 1. Sep 2015, 09:19
When it go to work ? Because i misses it.
Re: QRG Band edges
Posted: Tue 1. Sep 2015, 09:30
I can activate it, but it won't satisfy you.
Re: QRG Band edges
Posted: Tue 1. Sep 2015, 14:48
Thats true, but now we have nothing
