Moving from MacLoggerDX to RUMlogNG
Posted: Sat 30. May 2015, 10:20
Hi all!
First post on the forum. Haven't read any manuals yet, so forgive me if i ask questions for which the answers are documented in the manuals.
I am looking if i can move from MacLoggerDX to RUMlogNG. So i installed RUMlogNG and my first impressions/questions are the following:
Thanks and i keep fiddleing with the program until i have my setup right.
- In the DXCC Table i have several filter options. I don't do paper QSL, i only use eQSL and LotW. There is no option to only show DXCC confirmed by eQSL and/or LotW. Is that correct or am i missing something obvious?
- DX Spots. The only way to only show spots for Phone, CW and/or Digi is to to select what you want to see in the Preferences. Is there not a way to select these options straight from the DX Spots window?
- DX Spots window only shows spots if the DX Cluster window is open. Same for the Band Map. I assume that there is no way that RUMlogNG is able to logon to the cluster in the background not showing the DX Terminal window?
- In pile-ups i usually call by sending an audio file with my callsign to the radio over the serial port. Is that possible with RUMlogNG? I haven't found that option (yet). I know there is FLDigi support in RUMlogNG. Am i supposed to use FLDigi to get that functionality?
- In the DXCC Info box eQSL confirmations are not considered. Is that because the ARRL doesn't consider them as valid? Because i -do- consider them as valid.
