Feedback for NG 1.0.8
Posted: Mon 9. Mar 2015, 17:23
Hello Tom,
I am a new user of RumLogNG and I really like it!!! I first downloaded NG 1.0.7. I had a few problems with it, then I noticed you have made a new version 1.0.8 so I downloaded it and just completed a quick test of it.
As with the previous version, I am having a few problems with 1.0.8. Keep in mind I am a new user so some of these problems may be due to my inexperience with RumLogNG. I am running on an iMac with 10.9.5.
1. When I upgraded from 1.07 to 1.0.8 I notice several configuration entries were not saved. For example, my name and call were not saved but my user name for DX Cluster GB7MBC was saved. In general I have a lot of trouble getting my configuration to be saved. For example if I enter my LoTW user name and password, then try to enter my eQSL username, the LoTW username disappears.
2. Since I am a new user, my logbook has no QSOs or QSLs in it. I am having trouble getting any of my past ones in it. I have downloaded an ADIF file from eQSL of my past QSLs. That is stored on my desktop as eQSL.adi. When I do Logbook/Import ADIF, I get a message “Please disconnect from dx cluster first. Possible database conflict during background operation.”. So I disconnected from the cluster. Then I retried the Import ADIF. I still get the message. If I click through the warnings and try to import the eQSL.adi file, I find that it is grayed out on the menu that shows the list of files. This happens even if I restart and try without ever connecting to the cluster. I have renamed the file to eQLS.adif and that didn’t help.
3. When I restarted, the app still didn’t remember the path to the log file.
4. When I try QSL/LoTW In, I get a window with a list of QSLs in it. They are all red. The window shows that the QSos are not in the log. When I click Close, they are not added to the log. The same thing happens when I click QLS/eQSL In. If I click Read data from eQSL or Read data from LoTW, those QSLs disappear. I am not certain how to get them back. Because of this problem as well as problem number 2, I am unable to get any past QSOs into my log.
5. When I close all the windows, the RUmLogNG icon is left in the doc with the active indicator lit, but it cannot be used to gain access to the program. I suggest that it be deactivated when the main window is closed. Also when the main window is closed, maybe all other windows should be closed although other users may prefer to keep other windows up even when not logging.
6. Just a small thing, but the clock on the main screen for me shows “ 4:44:36” and then only a small part of the next characters which I think might be “AM”. It would help if you could make the time label a little wider.
7. Sometimes the Connect button on the DX-Cluster Terminal window is grayed out when the terminal is not connected. I can get this to happen if I close the window without disconnecting first. It appears the only way to recover from this is to close the app and restart.
Tom, please let me know if some of these problems are caused by my inexperience with your app. I suspect they are. Or if you need me to perform additional testing or send you screen shots, I will be happy to do either.
Also, do you have any interest in anyone helping you with your app. I am a java and .Net developer and I would love to have a reason to learn Xcode and Cocoa.
Best wishes,
Clark, AL7EK
Best wishes,
Clark, AL7EK
