Error for export to adif
ea7tb
Unread post by ea7tb »
Hello.
I have the following problem.
When I export a log to an ADIF file, the <dxcc> appears as -1 (<dxcc: 2> -1).
When I import this to another log log rum, the CAMCO DX appears as ??.
If I import another program, make no mistake dxcc and touch ups.
The temporary solution that I give is to edit the file and remove adif that field.
How can I fix this error export?
Greetings.
Hola.
Tengo el siguiente problema.
Cuando exporto un log a un fichero ADIF, el campo <dxcc> aparece como -1 (<dxcc:2>-1).
Cuando importo ese a otro log de rum log, aparece el camco DX como ??.
Si lo importo a otro programa, dar error en dxcc y no sube el contacto.
La solucion temporal que le doy es editar el fichero adif y eliminar ese campo.
¿Como se puede solucionar ese error de exportacion?
Saludos.
Manuel EA7TB. 73'
Re: Error for export to adif
Are you sure, you have the file "dxcc.rsd" in your RUMlog folder?
ea7tb
The file is onde Indica.
Only fault occurs when I export to adif.
When we introduce idicativo, it works correctly.
I performed the following test: I imported the adif file, the error appears.
Edit an invalid record, without rectifying anything, I keep it, and the error disappears.
El fichero esta onde indicas.
Solo ocurre el fallo cuando exporto a adif.
Cuando introduzco un idicativo, funciona correctamente.
He realizado la siguiente prueba: he importado el fichero adif, aparece el error.
Edito un registro erroneo, sin rectificar nada, lo guardo, y desaparece el error.
Manuel EA7TB. 73'
Do you have logged the affected QSOs in RUMlog or were these QSOs imported?
ea7tb
Hello.
I attached two files, one is generated Fldigi (Fldigi.adi) and the second rumlog.adi, to be served as an example
The first file I have imortado to RUMlog, and has not given problem.
When I upload the second file to QRZ.com, gives me error all those <dcxx: 2> -1.
Any Idea?
regards
fldigi.adi.zip
(1.76 KiB) Downloaded 776 times
fldigi.adi.zip
rumlog.adi.zip
(1.56 KiB) Downloaded 774 times
rumlog.adi.zip
Manuel EA7TB. 73'
Thanks for the files. There is an ADIF import bug in RUMlog. It shows the DXCC info correct, but it is not saved correct in the database. I fixed that. Before you import new QSOs, please download the latest version.
To correct the problem with always imported QSOs, you have to recalculate all DXCC entities using Menu-->File-->Recount DXCCs
Download the application only: http://dl2rum.de/rumsoft/RUMlogApp.zip
ea7tb
Hello.
Now works correctly.
Thanks for everything.
Greetings. :D :D :D
Manuel EA7TB. 73'
