RUMlog 3.2.3
Posted: Wed 14. May 2008, 16:37
Hi folks
Three new features where added in RUMlog 3.2:
1. Logging of QSOs from cocoaModem is possible now via AppleScript
2. Macros in the Telnet terminal allow now to send frequently used commands to the cluster just by a mouse click or via menu short cuts.
3. RUMlog can alert you via e-mail about new ones or selected call signs
Thanks to Rick, K6LE and Flavio, IK3OCD for the hints.
Read the attached What's new??? file in the RUMlog folder.
Direct Download:
http://www.dl2rum.de/rumsoft/RUMlog.zip
Re: RUMlog 3.2
Posted: Sun 18. May 2008, 14:35
by K6LE
Once I got the email settings right under the LoTW tab the text alerts work great!
In fact, yesterday when I was outside getting the BBQ ready I got an alert for a new one. Came back in here to the "Ham Shack" was able to quickly work him and then back to the BBQ!
RUMlog 3.2.1
Posted: Sun 18. May 2008, 15:44
One bug is fixed and one improvement was made:
The system menues and -textes are now in english again.
When you have set a dx alert and the e-mail sent out fails, you will get now an info about the reason for better trouble shooting.
Direct Download:
New in RUMlog 3.2.2
Posted: Mon 23. Jun 2008, 18:31
I've added some new ADIF conform modes to allow logging in these modes.
Following modes are supported now by RUMog:
AM
AMTORFEC
ASCI
ATV
CHIP64
CHIP128
CLO
CONTESTI
CW
DSTAR
DOMINO
DOMINOF
FAX
FM
FMHELL
FSK31
FSK441
GTOR
HELL
HELL80
HFSK
JT44
JT65
MFSK8
MFSK16
MT63
OLIVIA
PAC
PAC2
PAC3
PAX
PAX2
PCW
PKT
PSK10
PSK31
PSK63
PSK63F
PSK125
PSKAM10
PSKAM31
PSKAM50
PSKFEC31
PSKHELL
Q15
QPSK31
QPSK63
QPSK125
RTTY
RTTYM
SSB
SSTV
THRB
THRBX
TOR
VOI
Please note that some popular modes like QPSK... are not supported by the Logbook of The World. For LoTW only the following modes are allowed:
CW
PHONE
DATA
AM
FM
SSB
ATV
FAX
SSTV
AMTOR
CLOVER
FSK31
FSK441
GTOR
HELL
HFSK
JT65
MFSK16
MFSK8
MINIRTTY
MT63
OLIVIA
PACKET
PACTOR
PSK125
PSK31
PSK63
Q15
RTTY
THROB
The TQSL program can map the modes in an ADIF log file that aren't valid to modes that are valid via the File menu Preferences command (use the ADIF Modes tab).
Thanks to Karl-Heinz, DF7KHK for the hint.
Direct Download:
Re: RUMlog 3.2.3
Posted: Thu 3. Jul 2008, 19:22
Two smaller features were added:
After program start the log is set now to the last logged frequency and mode, not longer to 21005 in RTTY. This is affected only, when you don't have a TRX connected.
The new ADIF tags (since ADIF spec. 2.2) <LOTW_QSL_RCVD> and <LOTW_QSL_SENT> are used now. The tag <app_rumlog_lotwqsl> is only used for ADIF import now, and not longer used for the export function.
Direct Download:
Re: RUMlog 3.2.3
Posted: Fri 4. Jul 2008, 02:32
by n2fq
Hello Tom..
Great.
Are you thinking of supporting the rest of the ADIF 2.2 tags?
If not, would it be possible to append the tags and values as you parse them to the notes field?
I'm speaking of tags whose values are not null.
tnx for a great program.
Other new ADIF tags?
Posted: Fri 4. Jul 2008, 08:31
which tags do you mean? Unfortunately the site
http://www.adif.org/ is not up to date, and shows only 2.19. So I don't know other new ones. Currently RUMlog works in the following way concerning the Note field:
For export RUMlog uses the <comment:> tag for the text in the Note field.
For import RUMlog uses the <comment:>, <qth:> and the <name:> tag to put all into the Note field.
Any further suggestions are appreciated.
Re: RUMlog 3.2.3
Posted: Sun 6. Jul 2008, 01:13
by n2fq
Hello Tom
Oops.. I have the ADIF 2.0.
Specific tags I'm referring to are PFX, CNTY,RIG,AGE..
However, now I realized from your reply that export would consider the whole note field as
a comment. I didn't think about that.
So ignore my idling..
tnx. again for a great program.
