Not talking to Yaesu dx500
Posted: Mon 1. Jul 2013, 22:28
by kb1qu
I haven't been able to get RUMlog to talk to the dx5000 (via Microham USB III) since I moved the shack. The CAT light goes on, but no other communication. Maclogger Dx communicates fine. I am using the FT 1000MP transceiver setting in RUMlog whereas in ML DX, there is a dx5000 option.Can't figure out what I changed. Any ideas?
Chip.
Re: Not talking to Yaesu dx500
Posted: Tue 2. Jul 2013, 05:19
You should post a screen shot of your TRX settings.
Posted: Tue 2. Jul 2013, 15:57
by kb1qu
Here it is, Tom
Posted: Tue 2. Jul 2013, 18:26
Try to switch on the options "Use DTR" and/or "Use CTS" to enable flow control. Per default it is switched on in the trx.
I guess, the baud rate matches? I was not able to find any information about the number of stop bits.
Posted: Tue 2. Jul 2013, 20:43
by kb1qu
Those changes didn't make a difference. I have tried to match the config from MLDX which does work, but without success. I'm sure I'm missing something obvious. Here's the MLDX prefs:
Posted: Wed 3. Jul 2013, 17:17
No idea. It was working before?
Posted: Thu 4. Jul 2013, 13:38
by kb1qu
Yes...I'll keep tinkering with it and see what I can figure out. Thanks.
Posted: Thu 18. Jul 2013, 13:44
by kb1qu
Hi, Tom
Finally got it working. All I had to do was use the FT2000 xcvr setting rather than the FT1000. It took me way to long to figure that one out. Now I am working on integrating the Cocoamodem functions through the Microham USB Interface III. It looks like that is not supported through the CW preference panel. I guess I will have to operate those modes in Cocoamodem and log the contacts into Rumlog.
Thanks.
