Label printing
Posted: Thu 9. Aug 2012, 17:30
by NF4L
I don't see anything on the Label Editor about address labels (p 67 of manual).
Can RUMLog print return (my address) labels and manager address labels?
If so, how?
73, Mike NF4L
Re: Label printing
Posted: Thu 9. Aug 2012, 21:09
There are no options available for address label printings. Just select the paper and label size / layout in the Label Editor.
To print address or return labels query HamQTH.net or qrz.com in the Main Logging Window:
  • Enter the desired call sign into the call field (or your own for return address label)
  • Use Menu-->QSO--HamQTH.com lockup (or qrz.com lookup)
  • When data are shown in the drawer window or in the separate window use Menu-->QSL-->Add Address to Printer Queue
  • Repeat the steps above as required
  • Use Menu-->QSL-->Print Saved Adresses
Re: Label printing
Posted: Sat 11. Aug 2012, 12:46
by NF4L
Thank you Tom, and thanks for the new version! :P
That worked, but a couple of questions about it.
I used HamQTH.com, but the drawer said qrz.com.
When I print return address labels I want to print a whole sheet (3X10). Is there a way to tell RUMLog to print 30 labels other than adding my address 30 times?
73, Mike NF4L
Re: Label printing
Posted: Sat 11. Aug 2012, 13:51
I can't believe that.
No, not yet. I will put it on the To Do list.
Re: Label printing
Posted: Sat 11. Aug 2012, 22:16
by NF4L
I've never lied to you before.... :D
I just realized there are 3 sections to the drawer. The only one showing was QRZ. All well now.
Thanks!
