turn off "prefix doesn't match"
Posted: Sat 19. May 2012, 19:58
by aa0aa
Hi all;
I couldn't find any way to turn off the "prefix doesn't match" warning. There are so many combination calls (like mine-- XE1/AA0AA) that usually don't match for hams licensed in more than one country or for dxpeditions that this occurs all the time and usually is obvious (except on a call that was mis-spotted).
Is there a place in the preferences where this can be turned off except when needed?
If I missed it, please forgive me.
Scott AA0AA; XE1/AA0AA
Re: turn off "prefix doesn't match"
Posted: Sun 20. May 2012, 09:29
When do you see this message? Can't remember.
Posted: Mon 21. May 2012, 02:36
by aa0aa
Tom and all;
In my case it is when I click on a frequency of a DX spot in that window--right now, for example, CE2/VE7SV is one of the spots and when I click on that freq to transfer the call and frequency to the main logging window, that is when the small window appears over the main logging window that says "callsigns don't match".
It only is a bother because it blocks the program until you check the "ok" button.
Posted: Mon 21. May 2012, 09:29
There are hundreds of messages in RUMlog, what do you mean is: "Callsigns don't match!"?
This caution message appears, when qrz.com returns with an other call sign as requested. qrz.com can't handle portable calls. When you want to query "XE1/AA0AA" you will get the information for AA0AA. The operators name may be the same
but all other information are probably wrong. This box is shown only, when you have set the automatic logging masks filling up. This is to prevent, to enter wrong information like QTH, grid square, IOTA, etc.
Currently I don't have a better idea to alert the user. Recommendations are welcome!
You should use HamQTH.com rather than qrz.com. HamQTH.com allows portable callsigns and returns the correct information when available.
Posted: Fri 1. Jun 2012, 06:34
by aa0aa
DL2RUM wrote:There are hundreds of messages in RUMlog, what do you mean is: "Callsigns don't match!"?
If you click on a dx spot such as XE1/AA0AA the program will show a window/box that says "callsigns don't match" and wait for you to check the OK button before you can proceed. If this could be turned off and on in the preferences it would be helpful.
I observed this with many dxpedition stations in the WPX contest
Yes, it often puts the country correctly but everything else wrong.
I will try this and see if it works.
Scott XE1/AA0AA; AA0AA
