Page 1 of 2
Modem modes for RTTY
Posted: Thu 29. Dec 2011, 18:31
by N1JM
Can someone tell me what K3(TX) and cM(RX) works for RTTY.
Thanks and 73, John N1JM
Re: Modem modes for RTTY
Posted: Thu 29. Dec 2011, 19:29
For transmission, the Elecraft K3 internal routines are used. The K3 must be configured as TRX, because the CAT interface is used.
For RTTY demodulation, cocoaModem will be used.
Mostly I use this combination as you can see here:
http://dl2rum.de/forum/viewtopic.php?f=3&t=166
Posted: Fri 30. Dec 2011, 05:57
by N1JM
Thanks. Nice to be able to do FSK with the K3.
Posted: Fri 30. Dec 2011, 13:49
by N1JM
I noticed on the demo mov that the F key labels show above the RTTY window. I don't see them anywhere on my version (latest and latest cocoa modem).
73, John N1JM
Posted: Fri 30. Dec 2011, 13:55
by N1JM
Sorry, I spoke too soon. "Show macro buttons".
John N1JM
Posted: Fri 30. Dec 2011, 21:35
by N1JM
As of yet I do not see a way of going into a "terminal mode" for rtty(K3 tx cM rx) to have a casual quick exchange during a contest.
John N1JM
Posted: Fri 30. Dec 2011, 22:49
Not sure what do you mean. You can assign a F-key for quick exchange.
Posted: Fri 30. Dec 2011, 23:37
by N1JM
So you are saying that the only way to transmit in Rumped is through an F Key macro?
John N1JM
Posted: Mon 2. Jan 2012, 23:39
by N1JM
Quite often just before, during or after the contest I might have a short qso with someone without having to go to a different rtty program. You can do this in N1MM and Writelog just using the keyboard.
73, John N1JM
Posted: Tue 3. Jan 2012, 08:18
There is a keyboard mode as well.
Menu-->Transceiver-->Keyboard Mode or just Command K. Works similar for CW, RTTY and PSK. ( Don't know, why in the TRX Menu
Once in keyboard mode you can start typing. Press Command T to start transmission, press command R to switch to RX when all text is sent or press Escape to abort.
