WinKey and RUMLog no power
Posted: Sat 9. Apr 2011, 20:25
by N3LZG
I just finished assembling the basic WinKeyer 2 and have only one problem: it is not working with RUMLog.
I tested it out and have it working in RUMPed 100%, but can't use it on RUMLog, even with the same settings. The problem, as far as I can tell, is that the WinKeyer 2 is not getting power when I try to run it with RUMLog. "Set DTR Line" is checked and should be supplying voltage, but isn't.
Any suggestions?
73, Andrew
N3LZG
Re: WinKey and RUMLog no power
Posted: Sun 10. Apr 2011, 02:33
Since I build my Winkeyer into a CAT/sound card interface housing with a power supply from the USB port I was not able to test these settings.
It seems, I used the wrong settings during initialisation of thr COM port. Here is the corrected version. Please give it a try and report further.
http://www.dl2rum.de/rumsoft/RUMlogApp.zip
Posted: Sun 10. Apr 2011, 03:12
by N3LZG
Will do. Thanks for the fast reply.
Andrew, N3LZG
Posted: Sun 10. Apr 2011, 06:31
by N3LZG
WinKey works now, thanks.
Andrew, N3LZG
