DIGI KEYER II and RUMlog configuration
Posted: Sat 26. Mar 2011, 13:30
Hi Tom.
I am the proud owner of a new DIGI KEYER II. I want to integrate it with RUMlog and my Icom 746PRO. My goal is to work PSK and RTTY (FSK) from RUMlog and control the radio. At this point, I need some configuration guidance.
I have tried to configure RUMrouter, RUMlog and cocoamodem but have only been partially successful. Below are the configuration steps I have done and the results.
1. Configured the DIGI KEYER II jumpers for the ICOM.
2. Installed the latest mac drivers from http://www.ftdichip.com/Drivers/VCP.htm
3. Ran RUMrouter. "microHAM" is in green. "RUMlog" goes green when I start RUMlog. In the device list box, "usbserial-D2U3YX0D" is selected.
4. In RUMrouter, I opened the digikeyer II Preferences and selected "useAUTOPtt" and "PTT for Digital". I am not sure what I should set here.
5. In RUMlog preferences (TRX 1), I set TRCVR to "IC-7400 (66h) and checked "Use microKeyer" for the serial port.
6. In RUMlog preferences (Digi) RTTY: Modem - "cM + MKII (FSK)", PTT - MKII. PSK: Modem - "cocoamodem", PTT MKII. I am not sure if this is correct.
7. In RUMlog, the frequency and mode display changes as I change them on the radio - this is good!
8. When I double click on a DX cluster spot in the RUMlog logging window, the radio's frequency and mode DOES NOT change. Is there a setting I missed?
9. I tried RTTY. I selected RTTY mode on the radio and selected "Digi show controls" in RUMlog. Cocoamodem started. I clicked "Configuration" and set: Main receiver - Input = microham codec. source = ext line connector. Transmitter: Output = microham codec, PTT = VOX. The "Line" and "SC" lights on the digikeyer are lit. I can receive and transmit (into dummy load for now) OK.
10. I tried PSK. Set RUMlog mode to PSK and selected "Digi show controls". Radio mode is set to USB-D. I set Input = microham codec, source = external line connector. Output = microham codec, PTT = VOX (the digikeyer option is greyed out). My configuration is definitely not correct.The radio starts transmitting as soon as the configuration screen is displayed.
Tom, can you please provide some configuration guidance or point me towards some helpful documentation? I have read the RUMlog and RUM Router manuals. My main issues are I cannot get the radio to change frequency, band and mode and I cannot configure PSK. I have operated RTTY and PSK on windows PC's but not the Mac. I have not used cocoamodem either and am not running Chen's uH Router as I assumed your RUM Router is all that is needed.
I apologize for all the questions. I would be very very happy if I could use my Mac (a new iMac) for all my ham radio needs. Any assistance you could provide would be greatly appreciated.
Thank-you in advance,
Sheldon
VE1SJP
Sheldon
VE1SJP
