V6.0 - [RL UDP Broadcast] Network not available
Posted: Sun 28. Dec 2025, 14:27
by kc2o
After updating to V6.0 when I start RumlogNG I observe the following in the network window:
14:19:36 [Local] Listening to WSJT-X on port 2237
14:19:36 [RL UDP Broadcast] Network not available
14:19:37 [DxLab Server] Started
14:19:37 [Local] RC-28 daemon started
14:19:58 [localhost] WSJT-X checked in
14:19:59 [DxLab Server] Connection established to: localhost
Is this ok or does it indicate there is a configuration issue?
Re: V6.0 - [RL UDP Broadcast] Network not available
Posted: Sun 28. Dec 2025, 15:30
Sure, there is a problem. The question is: Do you have to use a RUMlog broadcast?
Posted: Sun 28. Dec 2025, 16:48
by kc2o
OK, No I don't think require broadcast, I turned off contact info to N1MM and issue no longer is reported:
16:45:19 [Local] Listening to WSJT-X on port 2237
16:45:19 [DxLab Server] Started
16:45:19 [Local] RC-28 daemon started
I may have been attempting to use N1MM for a contest in the past and had this set to share contact info.
