IP CAT connection to FTdx101 with SCU-LAN10
G0SNJ
Unread post by G0SNJ »
I'm trying to connect RUMlogNG to my FTdx101 with a SCU-LAN10 connected. My remote control software works throught this connection, so I'm using the same IP address. Can anyone tell me what port I should use for the CAT connection to RUMlogNG, and if there are any other settings that aren't obvious? Thanks, in andvance for any help. Regards Steve (G0SNJ)
la4sga
Re: IP CAT connection to FTdx101 with SCU-LAN10
Unread post by la4sga »
With the SCU-LAN10 unit the radio USB connector connects to the SCU-LAN10 unit, thus CAT can only be done through the network cable. To do this you have to run a dedicated server software. If your remote control software is the standard windows remote software from Yaesu, It has no CAT-server.
The commercial FT-Control software has a CAT Server in the MacOS version. FT-CONTROL
The open source project WFVIEW will probably support YAESU radios with the SCU-LAN10 in next version. I do not know the release shedule. WFVIEW
73 de LB2EG Richard
