IC7300: S&P is not activated by moving VFO
Posted: Fri 17. Oct 2025, 05:39
Description
By design: "S&P (Search and Pounce) will be activated as soon as you move the VFO", but with ic7300 it doesn't work.
STR
1. Open Contest window
2. Activate Running mode
3. Rotate VFO
Actual result
Running mode persists
Expected
S&P is activated
STR
3. Rotate VFO
Actual result
Expected
S&P is activated
