LoTW Indicator
Posted: Fri 22. Jan 2010, 21:48
by K6LE
The idea of having an indicator for stations that are on LoTW is a good one. But, it seems that if the call has the period after it in the DX Spots window it won't transfer up to the log by clicking on it.
I was wondering why some calls didn't transfer properly and then I noticed that the ones that don't have the tiny period after them.
BTW, Spot handles this info by showing those spots in italics.
Re: LoTW Indicator
Posted: Sat 23. Jan 2010, 05:49
Here it works fine, I can't find an issue. Do you use the latest 4.3.2?
Re: LoTW Indicator
Posted: Sat 23. Jan 2010, 12:26
by K6LE
Yes, working fine here this morning too.
Seems like several things got messed up when I tried to use the F5 key for CW. Including not working from the keyboard but sending from the CW control panel.
After a reload of the program things are back to normal. (except still can't send with any "F" keys higher than F4 - I'll just use the control panel for them).
Re: LoTW Indicator
Posted: Sat 23. Jan 2010, 19:25
Apple recommends not to use the F keys in own applications. When you have configured your system to use the F keys for OS-X (Spaces, Exposé, etc), then these keys are not visible in RUMlog.
Re: LoTW Indicator
Posted: Sat 23. Jan 2010, 20:06
by K6LE
I have the "F" keys set to be regular "F" keys instead of special ones and F1-F4 work fine but none above that.
Not a big deal, I'll just use the CW Control panel
Re: LoTW Indicator
Posted: Sun 24. Jan 2010, 04:54
This is another story, you have also to disable all other short cuts assigned to the other F keys in your system
preferences.
