Crash at start up after upgrade to Ventura 13.6.8 (22G820)
Posted: Wed 31. Jul 2024, 19:56
by VE3AJ
RumlogNG crash on startup after upgrade to Ventura 13.6.8 (22G820)
Down loaded fresh copy from Apple and Rumsoft no change
Tried fresh empty log from backup no change
Anyone else having this issue?
Jim
VE3AJ
VE7KAJ
Re: Crash at start up after upgrade to Ventura 13.6.8 (22G820)
Posted: Thu 1. Aug 2024, 18:42
by VE3AJ
Fixed
macOS corrupted file was issue
Posted: Sat 3. Aug 2024, 12:42
Which file was corrupted?
How did you find it out?
How did you fixed it?
The answers of these questions could help others.
Posted: Tue 6. Aug 2024, 02:05
by VE3AJ
Did not find a specific file
Other programs started failing
macOS was losing desktop settings between boots
Have not done a “clean install” for at least 4 years
Since everything is backed up to external RAID drives
I replaced SSD with a larger one and did a fresh install on the new SSD
No problems since then
