RL / Without Wire / FLDIGI
Posted: Wed 8. Dec 2021, 23:15
by N8ME
Can RumLogNG be used with Without Wire to connect to a IC7610 via LAN and control FLDIGI as it can WSJT-X?
Mark, N8ME
Re: RL / Without Wire / FLDIGI
Posted: Wed 8. Dec 2021, 23:43
Without Wire sits just in the middle between RL and the TRX. There is no change in the way the connection to Fldigi works.
Posted: Thu 9. Dec 2021, 01:27
by N8ME
Okay, I have Without Wire and RumLog working. The Icom IC-7610 control window can control the radio and responds to changes. But I can't get it to pass that information on to Fldigi. One of the posts here on the forum shows setting XMLRPC to localhost and the appropriate port, the setup screen shows the original tabbed dialog for setup, but the current version doesn't have a tabbed setup and there is no setting for XMLRPC other than for FLRIG. Is RL supposed to act like FLRIG?
Mark, N8ME
Posted: Thu 9. Dec 2021, 09:43
The last time I have used Fldigi, there was no separate option for XMLRPC. It's always active.
No, it doesn't work like Flrig.
Posted: Thu 9. Dec 2021, 18:32
by N8ME
Thanks for the reply. I'm having no luck getting RUMlogNG to control FLDigi (v 4.1.20 for BigSur). I do have RL working with WSJT-X. This is on a M1 Mac mini with Monterey. Attached are what I think are the appropriate RL and FLDigi confiig screens.
Mark, N8ME
Posted: Thu 9. Dec 2021, 19:13
You have to enter the host address where Fldigi is running.
Posted: Thu 9. Dec 2021, 21:38
by N8ME
That was it. Thanks!. I saw the 127.0.0.1 already in the field, so I thought that was the default.
Mark, N8ME
Posted: Thu 9. Dec 2021, 21:51
by N8ME
Now I've got it to where FLDigi does respond to changes on the 7610, but the 7610 doesn't respond to changes in FLDigi. Is the communication only one way? Or am I'm still missing something in my setup? T/R does work, but I can't change frequency or mode in FLDigi.
Mark, N8ME
Posted: Fri 10. Dec 2021, 00:04
Yes, this is one way.
Posted: Fri 10. Dec 2021, 00:07
by N8ME
