Auto Login to Cluster
Posted: Sat 4. Dec 2021, 14:49
by K1JX
I'm currently using the latest version of RUMLogNG on a MacBook Air M1 running the latest version of Monterey,
It appears that Auto Login to the DX Clusters doesn't work on a reliable basis. Sometimes when I start up RUMLogNG, I get logged into both Clusters I've set-up in the terminal. Other times, neither Cluster is logged in and I need to to manually select the tab for each to get them logged in. (They log in correctly with all the information then.)
I'm pretty certain that I must have a setting wrong. Suggestions?
Thanks!
