ICOM 9700 - Load Memory from File
Posted: Tue 16. Nov 2021, 11:16
by wb2pkr
I am trying to load the 2M Memories on the ICOM 9700. There is a button on the 2M Memories page that says "Load All From File" but I cant find any description of how the file should be formatted. I tried to use the "Save All To File" button but I could not read the file it created.
Can I use a CSV file and if so, do the fields need to be delimited? If so, what is the delimiter? Can I simply list in same order as the fields are presented on the screen? If not, where can I find a description of the necessary file format.
73, Ron WB2PKR
Re: ICOM 9700 - Load Memory from File
Posted: Tue 16. Nov 2021, 13:20
You can load files only you have saved before using this app.
