Icom 7610 CI-V address conflict
Posted: Sat 18. Sep 2021, 18:08
Im trying to get RUMlogNG 5.4.1 (473) OS X (10.13.4 High Sierra) to communicate with my ICOM 7610.
Initially, I simply selected CAT and it worked FB. However, in order to get my Tokyo Hypower amp (HL 1.5KFX) to automatically change bands, I needed to change the CI-V address to 5Ch in the 7610 config and connect the 7610 to the amp via the remote jack on the 7610. Once I do that, the CAT control does not work. If I set the CI-V address back to the default (98h), the CAT control works again, but the band change on the amp does not.
Any suggestions?
Ron WB2PKR
Any suggestions?
Ron WB2PKR
