Can't record audio from any input device.
Posted: Thu 12. Aug 2021, 22:21
by k4zrj
I am unable to connect to any audio source and record audio using any of the three methods from the Audio menu entry. I can play a previously recorded audio file, but cannot record a new one. Other programs such as "Audacity" that record audio from external devices such as USB CODECs work fine. Wanted to record a W1AW code practice session for later use.
I am running version 5.6.3 of RUMlogNG under macOS 11.5.2. Don't when this issue started, as it has been a while since I tried to record audio using RUMlogNG.
Ideas?
73, Charles, K4ZRJ
Re: Can't record audio from any input device.
Posted: Fri 13. Aug 2021, 02:26
Check your System Privacy settings. You have to allow Microphone for RUMlog.
Posted: Fri 13. Aug 2021, 03:10
by k4zrj
Knew it would be something simple. Tnx
