Without Wire Documentation?
Posted: Mon 9. Aug 2021, 23:02
by KT4ZE
Is there any documentation or help files for Without Wire?
Re: Without Wire Documentation?
Posted: Mon 9. Aug 2021, 23:09
See the Help menu.
Posted: Tue 10. Aug 2021, 04:50
by KT4ZE
Well there it is! I knew I had seen it somewhere. Thank you.
I can't seem to use the 'Icom Client (W)Lan' to connect RumlogNG to the 7610. I can connect using the TCP/IP Server (CAT:Serial Port set to Auto-Discovery in RUMlogNG). When connected this way all works great. What do I need to do for a Lan connection?
Posted: Tue 10. Aug 2021, 09:09
You have to connect RUMlog to the WithoutWire app via tcp/ip and WithoutWire to the TRX.
Which part is not working?
This doesn't make any sense to me.
