RumlogNG, Fldigi and TS-590 - won't transmit
Posted: Fri 23. Jul 2021, 02:23
by AG7AB
I have RumlogNG working great with my TS-590 using CAT via the USB port. Tuning, CW transmission, logging. All is great. Now I am trying to get Fldigi to work with this. I have the interface mostly working. CAT interface from RL is fine, reception via USB audio is working, PTT via CAT command works, but I can't get it to transmit using PSK31. The rig goes into transmit, but no transmitted power is indicated on the 590. I have the 590 options set to use USB audio and have tried different audio input levels. Searching for solutions, I see that the 590 requires a CAT TX1 command rather than TX0 to tell it to use the USB audio rather than the Mic audio. Does RL send the TX1 command when getting a PTT request from Fldigi? Any other suggestions are much appreciated.
Mike
AG7AB
Re: RumlogNG, Fldigi and TS-590 - won't transmit
Posted: Fri 23. Jul 2021, 08:45
RUMlog issues always the CAT command TX1; for PTT on when using the TS-590 selection.
Make sure you have configured RL to use CAT PTT, not DTR nor RTS.
Posted: Fri 23. Jul 2021, 19:32
by AG7AB
Thanks for the confirmation, Tom. Yes, PTT is set to "TRX CAT". I'll continue to investigate.
Mike
Posted: Fri 23. Jul 2021, 19:42
Here you can find a tool which may be helpful for CAT trouble shooting:
https://dl2rum.de/RUMlogNG/TCP2Serial.zip
It has to sit in the middle between RUMlog and your TRX. You connect RL to this app via tcp/ip.
Posted: Fri 23. Jul 2021, 22:36
by AG7AB
OK, red face here. As we say, it was an ESO problem (Equipment Smarter than Operator). Found I had the computer sound output volume turned down all the way. That was intentional, since I thought that would only affect the speaker output, but apparently affects the USB output level as well. it's all working now. Except now I need to get the logging script working. Also having fldigi crash a lot. This is the latest 4.1.19, but doesn't seem very stable to me.
Mike
