Page 1 of 2
"real time synchronisation"
Posted: Sat 26. Jun 2021, 13:58
by W6JCH
I have a problem that real time synchronisation with ClubLog appears to not work
I can still do manual updates with the "Upload new QSOs to Club Log" command but the real time does not work, any ideas?
I do have the clublog info in preferences complete and the Real time synchronization box checked
Re: "real time synchronisation"
Posted: Sat 26. Jun 2021, 14:10
After updating or saving a new QSO a Club Log status message above the Station Info Box should appear. What does it say?
Posted: Sat 26. Jun 2021, 23:05
by W6JCH
Just above the the station info box it just says
Clublog info
That was only after I selected the QSO line for the just logged QSO in the logbook table, before that it referenced a different QSO inside the station info box
I am using
RUMLog 5.5
WSJT-X 2.4.0
JT-Bridge 3.4.3
Gridtracker 1.21.0620
MAC OS 11.4
Posted: Sun 27. Jun 2021, 08:49
Once again: A useful message should be seen after updating or saving a new QSO.
Posted: Sun 27. Jun 2021, 17:07
by W6JCH
After logging a new QSO the station info box does not change it still has a old Call sign in it. (logged from WSJT-X)
The message just above the station info box\x just says "Clublog info" nothing else
I dont get the pop up alert widow that says the was a new contact logged either
The new QSO does appear in the lag file
If I select the new contact in the log file the info in the station info box updates to the the new contact and says 2 QSOs and the sunrise etc. but the message above the the box still just says "Clublog Info"
Posted: Sun 27. Jun 2021, 18:25
by W6JCH
I removed Grid Tracker.......no change
Posted: Sun 27. Jun 2021, 20:03
by W6JCH
the popup a.ert that a new contact was logged was a result of DND being on ...cthat problem is gone
Posted: Sun 27. Jun 2021, 21:44
When the status message never changes, then there is no upload.
How do you log your QSOs? Per script or manual entry?
Do you use the iCloud synced logbook?
Was it working before?
Posted: Mon 28. Jun 2021, 00:29
by W6JCH
I log it from WSJT-X when to prompts to log the QSO,
I get the popup, and the audible ping that says the QSO was logged
Nothing in the station info box changes it still contains the call sign displayed before the logging took place,
The contact is in the log file but the log log file does not automatically scroll up the content so it is visible, I must do it manually
No, I do not use an iCloud synced logbook everything runs on the same mac
WSTJ-X provides the rig control
Yes it was working before, it quit maybe around the the time I upgraded to Big Sur OS
Posted: Mon 28. Jun 2021, 09:29
Keep the process simple at first. Just enter a call sign and save it.
You have to watch to the text
above the box, not in the box.
The log table scrolls only, when you have sorted it by date!
