WSJT-X Auto issue
Posted: Mon 11. Jan 2021, 17:31
Here is what I have setup
WSJT-x 2.1.2 running on a linux (Ubuntu 20.04) Intel Nuc sending UDP data to the laptop on 2237
RumLogNG 5.2 running on my OSX BigSur Laptop
Here is what IS working
WSJT-X QSOs are logged in RumLogNG
WSJT-X is sending info to DXCluster to RumLogNG
RumLogNG is triggering transmit on WSJT-X when the "auto" button is checked in the network window
What isn't working
Once an auto transmit is sent, WSJT-X continues to transmit until the watchdog timer kicks in.
It appears RumLogNG is not sending the "stop Transmit" command after 3 transmits (per user manual)
RumLogNG doesn't add the callsign to the 20 minute block list and so even after hitting a watchdog timer (5 minutes) RumLogNG triggers another transmit to the same callsign.
Any Ideas?
What isn't working
Any Ideas?
