is RUMlog NG Big Sur ready?
Posted: Tue 17. Nov 2020, 15:28
by EA5Q
Does any body know if Big Sur affects RUMlogs normal operation.
Another story will be the USB control of accessories.
Will IC7300 still be directly operative via USB on Big Sur with RUMlogNG?
Thank you!
Re: is RUMlog NG Big Sur ready?
Posted: Tue 17. Nov 2020, 15:45
Yes.
Elecraft and Icom will work fine, out of the box. No driver needed. Yaesu may be a problem.
Posted: Tue 8. Dec 2020, 20:14
by James
Since I read that the Yaesu may have a problem, I am delaying the Big Sur update.
I use RumlogNG 5.0.3(437) whit FT-857D and MKIII and it works fine.
What kind of problem can I find?
Greetings and thanks.
Posted: Fri 11. Dec 2020, 11:53
by KN4SMO
I am running 5.1.1 RUMlogNG with Big Sur while using a Yaesu FT-991A.
I can not get Control of the radio.
This program has worked in the past using this computer and radio settings?
Do I need to update drivers? It appears not but I am just asking for some direction to fix the issue.
Thanks KN4SMO Scott
Posted: Fri 11. Dec 2020, 12:00
Pending on the used chip set in the Yaesu you have to install the correct driver. Check the Si-Labs web site for further information.
Bis Sur will work with all Icoms but not with all Yaesus.
Posted: Sun 27. Dec 2020, 11:04
by KN4SMO
Hello Again,
Has anyone gotton the Ft-991A to work with Rumlog. I hope I have the latest drivers installed from Is-labs
KN4SMO/ New Call N2OG
Posted: Sun 27. Dec 2020, 11:18
by KN4SMO
Hello Again,
Yaesu FT-991A now works with Silicon Labs Macintosh OS VCP Driver v6, and the latest Big Sur update which arrived this morning.
