WSJT-X multicast/broadcast and duplicate logs
Posted: Wed 29. Jul 2020, 13:25
by MM6MRQ
Hello everyone,
I'm a new user of RUMlogNG and I've encountered something odd that I'm hoping someone can help me with.
I'm primarily using the application to log QSOs from WSJT-X and I'd also like to use JT-Bridge.
I've found that in order to have all three applications talking to each other I need WSJT-X to use a broadcast or mulitcast address - in unicast mode starting JT-Bridge breaks the connection to RUMlogNG, and vice versa.
The problem I'm seeing now is that when I click to log a QSO from WSJT-X I get two identical ones reported and logged by RUMlogNG.
Has anyone else encountered this or have any suggestions that might fix it?
Thanks in advance,
Mike
Re: WSJT-X multicast/broadcast and duplicate logs
Posted: Sat 19. Sep 2020, 09:07
by MM6MRQ
After a while this stopped happening, and it's been fine since.
Finding rumlogng really useful - thanks for your work on it.
Mike
Posted: Sat 19. Sep 2020, 09:12
You can get multiple logged contacts, when you have multiple network connections. I.e. LAN and WLAN active.
Posted: Thu 22. Dec 2022, 16:13
by n8sqt
This helped me with my setup using GridTracker and HamClock. HamClock is running on a Raspberry Pi and I needed to use the broadcast address to get the data up there. I figured I'd send a reply to add these search terms ;-)
Thanks & 73,
N8SQT
