Is Catalina safe ?
Posted: Tue 10. Dec 2019, 21:29
by Louis ON5EN
Is Catalina 10.15.2 safe to use with RumLogNG 4.4.1 & TQsl & LotW & others ?
Any (older) Software that is causing trouble ?
tnx es 73 de Louis ON5EN
Re: Is Catalina safe ?
Posted: Thu 12. Dec 2019, 10:00
by g0vgs
RUMLogNG seems to be fine on Catalina, although I have had some issues with the window positions not being remembered.
73 Ian
Posted: Fri 13. Dec 2019, 10:47
by Louis ON5EN
Hello Ian, while I have no doubts whatsoever about RumLogNG, I do have doubts about TQSL & LotW,
since the ARRL seems to be in no hurry to go 64bits.
Maybe TQSL 2.5.1 is OK now, so they say, but I have grown a distrust about all things M$ hi...
This WE I will take the jump, make a full back-up first, upgrade to Catalina afterwards, run a check and hope for the best...
tnx fer info es 73 de Louis ON5EN
Posted: Fri 13. Dec 2019, 14:19
by K3DCW
Yes, it is just fine.
TQSL, RUMlogNG, Fldigi, WSJT-X, and most other software than ran on the last macOS runs just fine on Catalina as well. All are or have 64-bit versions available. Of course, by "older" software, if you mean non-64-bit software, then you'll have problems.
Posted: Fri 13. Dec 2019, 18:27
by Louis ON5EN
Tnx for your reply Dave, quite a relief !
Tomorrow I will go visit the 75 yrs Battle of the Bulge activities in Bastogne (OR75NUTS)
so I know what to do on Sunday hi.
tnx agn, MXM es HNY de Louis ON5EN
