Page 1 of 2
lotw setting
Posted: Mon 9. Sep 2019, 17:14
by lu6oa
I need help configuring lotw setting in window (Select patch tqsl Folder), I go to the folder "Aplication" Tqsl is shaded and cannot be opened.
Re: lotw setting
Posted: Mon 9. Sep 2019, 17:23
Your .tqsl folder is located in your users home directory. Note the leading period in .tqsl!
Re: lotw setting
Posted: Tue 10. Sep 2019, 00:03
by lu6oa
mpossible to configure lotw, I don't understand why my TQSL folder, when I try in the window "selections path to the Tqsl folder"
I go to the tqsl folder is disabled, please can you send me the routine according to my Finder.
thank you.-
Re: lotw setting
Posted: Tue 10. Sep 2019, 07:55
See the attached screen shot.
My
computer is named
MBP2019
My
drive is named
Macintosh HD
My
user (German word is
Benutzer) is named
dl2rum
Re: lotw setting
Posted: Tue 10. Sep 2019, 12:29
by lu6oa
Hello friend, I'm sorry, I can't configure, graphic sending, the TQSL folder is not available, I can't click on the File.-
Re: lotw setting
Posted: Tue 10. Sep 2019, 12:38
tqsl.app is not the .tqsl folder! The .tqsl folder will be created by the tqsl application automatically. Do you have got tqsl configured and running?
You can't see this folder in the Finder, it's hidden! But you should find it using the provided button Path to .tqsl folder
Re: lotw setting
Posted: Tue 10. Sep 2019, 17:45
by lu6oa
Hi ..! I have running TQSL outside the Rumlog , I have no problems to execute it, but in the Finder it is hidden with shadow, load again the Trusted QSL program and run it without problems outside the Rumlog program, but in Preference, Rumlog does not find the Tqsl route.
Thank you very much for the assistance and patience.
Sorry, my English is not very good
LU6OA, Oscar
Re: lotw setting
Posted: Tue 10. Sep 2019, 18:41
I'm sure it is there! You should find out how to view hidden files on your system. On a German system I have to press Shift & Command & Period in a Finder window.
Re: lotw setting
Posted: Tue 10. Sep 2019, 21:14
by lu6oa
Hi Tom, impossible, I can not configure loTw in RumLog, if you have any other solution for me let me know. Thank you.-
LU6OA, Oscar
Re: lotw setting
Posted: Tue 10. Sep 2019, 22:28
You could allow me to remote control your computer via iMessage.
