DXLab Suite control, send mode USB-D when chaging frequency
Posted: Sat 27. Jul 2019, 10:36
by dm2kg
I want to control RUMlogNG and the connect TS590SG via the DX Laub Suite TCP connection.
If works, but when I send:
<command:10>CmdSetFreq<parameters:23><xcvrfreq:10> 7.047,500
RumLOG send the Frequency command to the rig, but also "MD2;DA1", so it changes the mode to USB-DATA; I think it should not.
This also prevents my from using "Mode None" in WSJT-X's radio settings...
Am I missing something here?
Best regards, fantastic program!
kai /dm2kg
Re: DXLab Suite control, send mode USB-D when chaging frequency
Posted: Sat 27. Jul 2019, 13:51
RUMlog supports only a subset of the CAT commands, required for the WSJT-X operation. RUMlog sets always the mode you have selected for PSK.
Posted: Sat 27. Jul 2019, 16:48
by dm2kg
ok, understood.
Maybe RUMlogNG could also get an option to not change the mode in the future.
Thanks a lot!
kai /dm2kg
Posted: Sat 27. Jul 2019, 16:53
Why? What’s your operating scenario?
Posted: Sun 28. Jul 2019, 06:38
by dm2kg
I want to sync and control my TS-590SG (controlled by RUMlogNG) with several more external programs via TCP/IP, mainly for keeping external SDR receivers in sync.
I tried the DX Lab Suite interface (mode switching trouble) and the xmlrpc interface (cannot get the right "double" format with python3 xml-rpc lib).
What other possibilities are there to control RUMlogNG and the rig via TCP?
Or do you have some sample code for controlling via Xml-Rpc?
Thanks a lot,
kai
Posted: Sun 28. Jul 2019, 08:55
Getting TRX data out of RUMlog is easy using Applescript or the UDP broadcasts.
For controlling the TRX via RUMlog I could add some Applescript or DXLab Suite Commander commands.
Posted: Sun 28. Jul 2019, 13:01
by dm2kg
that would be perfect!
DX Lab Suite preferred, but then I still have the changing mode...
best 73,
kai
Posted: Sun 28. Jul 2019, 20:56
by dm2kg
not much needed:
- set freq / get freq
- set mode / get mode
