Macro for ICOM 7610
Posted: Mon 19. Mar 2018, 16:16
by F5HFZ
Hi All
I am using the test version of RUMlogNG with the control of the Icom 7610.
I would like to write "complex" macro for the Icom 7610, but it seems impossible to send more then one command CI-V in a macro. This is easy for the elecraft K3 ou KX3 and very handy for split pileup.
Do I miss something ?
Best 73
Nicolas, F5HFZ
Re: Macro for ICOM 7610
Posted: Mon 19. Mar 2018, 17:05
You can put multiple commands in one macro.
What do you want to do?
Posted: Mon 19. Mar 2018, 19:00
by F5HFZ
Hi Tom
It is a very good news but I don’t find anywhere the syntax for the concatenation of several commands (like ; for elecraft). I tried to start a new command ( FE FE.....) after the FD of the previous command..it didn’t work ...
For exemple I would like to have a macro for a pileup in CW :
Main to sub
Sub + 1 khz
SPLIT
Dual watch
Filter 3 for main
Filter 1 for sub
Dual scope center with 2.5
etc....
I am able to program each command ...but not together in a single macro .
Any help will be really apprecied...
Best 73
Nicolas
Posted: Mon 19. Mar 2018, 20:08
Hmm, Icom doesn't like commands in a fast sequence. Try this:
http://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
Just separate commands by a comma like this:
FE FE 98 E0 XX XX XX FD,FE FE 98 E0 YY YY YY FD
Posted: Mon 19. Mar 2018, 20:49
by F5HFZ
Many thanks Tom, i’ll try tomorrow morning and I will tell you if I get the result I am looking for.
Best 73
Nicolas
Posted: Tue 20. Mar 2018, 12:05
by F5HFZ
Hi TOM and All
Thanks you again Tom for the link for the new beta with 7610 Control. The "dynamic scope" is superb and really handy. I found two small bugs : no label for the macro 14, extra characters in the window of the QSY (I use a macbook pro with 10.12.6 OS).
I am now able to write a "complex macro" with 10 commands but I have to use the ASCII 44 (no comma possible in the macro editor) and to put A LOT of FE to slow down the macro (without the extra FE I have to run several times the macro).
So now everything's fine and RUMLog is perfect with the 7610.
Best 73 and thanks agn for developing RUMLog.
Nicolas, F5HFZ
Posted: Tue 20. Mar 2018, 12:25
Opps, I'm sorry for the comma. You are right. Just wondering how I got the comma in during testing.
Try build 232 without extra FEs and use the comma between two commands:
Which extra characters in the QSY box do you mean? Can you provide a screen shot?
Posted: Tue 20. Mar 2018, 17:35
by F5HFZ
Tom
I send u an email with two screen shots.
Nicolas
