Page 3 of 3
Re: Big Sur Update Broke RumlogNG for me
Posted: Thu 19. Nov 2020, 11:21
Try this please:
https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip (at least build 444)
When it still crashes, I have to make some more changes.
Posted: Thu 19. Nov 2020, 15:42
by K9QJS
Thanks for the version to test. Yes, it fails, when I click on the RumLogNG screen in the "Name" field. Failed this way two times. I did have successful FT8 QSOs when I did not change the screen focus to RumLogNG with this test version. Yesterday, in the previous version, I worked 10 FT8 QSOs with no crash. I have not yet moved my data file out of Dropbox.
So, there is a workaround for me: to not select the RumLogNG window with my mouse while using WSJT-X. Easy enough.
73, Hoop
Posted: Sun 22. Nov 2020, 20:40
Here a new try:
https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip (at least build 446)
I removed some third party code which caused the crash. On the down side, few settings are not compatible with earlier versions. You have to set it again:
- In all Icom and Elecraft Control Panels:
- Saved to file Memories
- Saved to file Band Stacking Registers
- Saved to file Fixed Scope Band Edges
- List of your preset Dx Clusters
- Your dx-cluster colours setting (contest & logging)
When this version crashes again, pse provide the crash log.
Posted: Sun 22. Nov 2020, 22:22
by K9QJS
Tom - No crashes during 5 WSJT-X QSOs, doing the same user activities that I did before which pretty consistently had resulted in crashes every time. I'll do more tests later today and tomorrow and will advise. Looking good so far. Danke schon, 73 Hoop
Posted: Mon 23. Nov 2020, 18:21
by K9QJS
I did a few more QSOs today. No crashes. Working FB. 73 Hoop K9QJS
