Page 3 of 4
Re: CAT Control issue WSJT-X->RUMlog using Kenwood TS590S
Posted: Wed 30. Aug 2017, 19:48
by EA3HOE
Issue is fixed. Bill G4JWS pointed me to the fact that in WSJT-X -> Preferences -> Radio -> Mode should be set to 'None'.
All working now.
Posted: Wed 30. Aug 2017, 20:29
Fine, I will add a note in the docs.
Posted: Wed 30. Aug 2017, 20:38
EA3HOE wrote:Still crashes...
Hmm, hard to track. Try this:
http://dl2rum.de/RUMlogNG/TCP2Serial.zip
When it crashes again, please send me the full crash log as file, not just the pasted text.
Posted: Thu 31. Aug 2017, 08:22
by EA3HOE
This one works! "Unfortunately" my CAT issue is resolved already. I'll send you the details by personal mail so you can have a look at it and improve if needed.
Posted: Thu 19. Oct 2017, 02:55
by va3cp
I have a Kenwood TS570s and when using either JT65 or FT8 modes, after each transmission, my radio switches to LSB.
Also, when I change bands in WSJT-X, the radio changes to LSB. If I set the radio to USB, then change bands in WSJT-X, once again, it switches to LSB.
In WSJT-X preferences > Radio, I have Mode set to None and Split Operation set to None.
WSJT-X is successfully sending data to RumlogNG including the logging function.
Do I have something configured incorrectly?
Posted: Thu 19. Oct 2017, 05:31
Check your TRX settings in RUMlog. When WSJT-X is in command, it sets the mode you have selected in RUMlog for the PSK mode. USB Data should be here a good choice.
Posted: Thu 19. Oct 2017, 12:18
by va3cp
I checked the RumlogNG preferences and for TX 1, the PSK mode was already set to USB.
When I change the PSK mode to LSB, WSJT-X can change bands and will put the rig in USB mode. After each WSJT-X transmission, the TS570s sounds the CW letter F.
Posted: Thu 19. Oct 2017, 14:40
Do you use a TS570 or a TS590?
Posted: Thu 19. Oct 2017, 15:04
by va3cp
Tom, I have a TS-570S.
Posted: Thu 19. Oct 2017, 15:45
Okay, I've read everywhere TS-590 in this thread.
You are right, for the TS-570 LSB and USB is swapped for the PSK mode. It will be fixed in the next update. I can't see a reason for CW keying, maybe the WSJT-X function?
