List of supported contests
m1dse
Re: List of supported contests
Unread post by m1dse »
Hi, where do I enter the IOTA reference when I select IOTA contest? I don't see an IOTA field.
Paul / M1dse
Into "Rcvd Number" field.
Enter QSO serial number and IOTA reference number separated by a space.
aa4oo
Unread post by aa4oo »
DL2RUM wrote:Where should the ARRL Section information come from?
Why dealing with ADIF, was the Cabrillo output from the General contest not sufficient?
Unfortunately the section info isn't available in a computer friendly form.
http://www.arrl.org/section-abbreviations
The General contest didn't provide for separate fields for the station class and section, or I misunderstood how to use it.
In the General contest you can enter multiple control number parts separated by a space.
I know about the ARRL section. My understanding was, you want to auto populate the section after entering he callsign?
aa4oo
Yes we separated the station class and section by a space but it needed to be separate fields in the ADIF to merge with the other stations logs.
We manipulated the resulting ADIF to break out the number field to be two separate fields for import into N1MM...
ARRL_SECT
APP_N1MM_EXCHANGE
Also changed the contest name to ARRL-FD
K8AJS
Unread post by K8AJS »
The ARRL does not use Cabrillo log format for Field Day; if you want to submit a Cabrillo log you can, but you must also submit a complete summary sheet. The "log" that is usually submitted for Field Day is just a dupe sheet, a list by callsign, with separate sections for each band. There are many other point-generating segments of Field Day making it mostly impossible to calculate contest score from the log alone.
The ARRL Field Day Entry Form is submitted at http://www.b4h.net/cabforms/fielddayentry.php Fifty bonus points for submitting the summary sheet through this page.
The ARRL Section list, with the abbreviations that are used for contest logging, is found at
Hope this helps.
John K8AJS
John Bastin K8AJS
bastinj@gmail.com
K8AJS
If you want to have the sections pre-filled for you during the contest, most people are using call history files from previous logs to obtain the information. As always, you must make sure you enter in your log what you hear during the exchange, and not blindly depend on the pre-filled information.
John K8AJS
John Bastin K8AJS
bastinj@gmail.com
nx1k
Unread post by nx1k »
I would like to see the New England QSO Party Added. Rules are at http://www.neqp.org/rules.html
Exchange is RST and SPC for non-New England. RST, County, and State. List of New England States and Counties is at http://www.neqp.org/counties.html My preference would be that you pre-populate State and County from previous log entries.
Thank you,
Mark/NX1K
KI4STU
Unread post by KI4STU »
ARRL Sections are listed here: http://www.arrl.org/section-abbreviations
The menu on the left of that page has other details about the sections, if needed.
The "abbreviation" is the exchange on the air, and in the log. A common exchange for this contest might be: <CALLSIGN> <CLASS> <SECTION>
For example: KI4STU 2A VA
The class consists of a digit indicating the number of transmitters followed by a letter indicating class of operation (e.g. A = portable, C = mobile, F = Emergency Operations Center; the rules list all of the classes). The number of transmitters is limited only by the number of available bands. WARC bands are not allowed. But CW, Digital, and Voice are considered separate bands. Because of this, you can have 3 transmitters operating on 40M, one doing CW, one doing RTTY, one doing Phone ... this means 40M actually has "3 bands" for this contest. So the number of transmitters can actually get quite large. In 2016, the largest number of transmitters reported for the contest was 21. In 2015 the largest number was 19.
k3cka
Unread post by k3cka »
Could you add winter field day?
https://www.winterfieldday.com/rules/
