RUMLog CAT (and WSJT-X)
Re: RUMLog CAT (and WSJT-X)
These problem can be caused by wrong PTT settings. When you have selected multiple PTT options, they will fight against. So you should check your settings for the PTT signal flow.
SD5M
Unread post by SD5M »
(See previous posts) My issue was the intermittent relay behaviour when double-clicking on a call to Enable TX in WSJT-X. This occurred after letting RUMlogNG handle the CAT. Setting the IC-7300 Set/connectors/USB Send/keying to DTR and the WSJT-X Preferences/radio/PTT method also to DTR solved it. Now, WSJT-X and RL appear to cooperate very well, as expected. 73, Rune, SM5DFM
