Page 2 of 2
Re: Without wires etc IC-705
Posted: Thu 27. May 2021, 22:28
by KC9WIB
I resolved my choppy signal issue
It's very important to use the audio midi setup utility and set the sample rate to 48khz
This solved my issue with both without wires and wfview
I was using black hole and sound flower and setting the rate to 48k made the issue disappear
Now I have a smooth and clean and strong signal
I used blackhole today - I assume same solution for soundflower
Also check on restarts of the computer- it might reset
Posted: Thu 1. Jul 2021, 22:22
by kf5wor
for the folks that have WithoutWires connected successfully to js8call - what rig type are you selecting in js8call?
I've got audio flowing through to my ic-705, but no CAT control.
Posted: Thu 1. Jul 2021, 22:31
Doesn't js8call support the IC-705?
Posted: Thu 1. Jul 2021, 22:42
by kf5wor
using version 2.2.0 for mac, I don't see a listing for the ic-705 in the rig dropdown list.
i was under the impression that WithoutWire could forward cat control commands to the ic-705 over the wifi connection. is this incorrect?
Posted: Thu 1. Jul 2021, 22:43
Yes, you are correct.
Posted: Thu 1. Jul 2021, 22:45
by kf5wor
ahh - i think i was missing that WithoutWire is exposing a TCP server that speaks the same protocol as the radio it's connecting to - not something like hamlib, correct?
Posted: Thu 1. Jul 2021, 22:49
It's just a relay, no intelligence inside.
